Using minilab 1008 by labview
I have minilab 1008 and i want to communicate with it by labview
I installed daq package its doesn't provide sending data over specified pin ( how i can do it )
(5,326 Views)
Did you install the LabVIEW Library?  Did you follow the examples in the documentation?  Did you try something simple first?
(5,320 Views)
I installed library but i want to know how i send vlaues through specific pins
( i connect one device but at physical channel i found Dev0 and Dev1 ) what is the right one cause i tried with 2 devices appears on labview , it reply with error " your device doesn't support operation "
(5,266 Views)
Hello M_Shaben,
You should be able to select the device and channel when using the ULx Create Channel VI, according to this youtube getting started video. The error message "your device doesn't support operation" implies you did not select the miniLAB 1008 device or the miniLAB 1008 does not support some ULx API functionality.
I would try following the youtube example and see if that works. Assuming it doesn't, I would then speak with Measurement Computing for help getting started with their hardware and driver.
(5,263 Views)
i see video but its about reading data analouge but its not help me
if any one work with daq systems or specially minilab1008
(about minilab 1008 : how to check status led by simple vi  by labview? )
and how to write data through two ports at same time by boolean button (on_off)
via rs422 to control external device 🙂
(5,245 Views)
Hello M_Shaban,
Is it possible to see your LabVIEW VI? If you are getting an error from the minilab 1008, you might need to contact the Measurement Computing's support since we are not familiar with their hardware or their driver.
Saki K.
(5,216 Views)
Accepted by topic author M_Shaban
Okay
Thanks all
I have to ask them about their product not you !!
Thanks again for help😎😎
(5,213 Views)
