Using library call nodes
I have attached a simple VI which uses a Call Library Node to open a serial communication port.  When I run this VI, LabView crashes.  I have attached the VI and the dll.  I have verified that the calling parameters are correct for the function.  Can anyone help me understand what is going on or how I can execute this or other CLN's using the same .dll?
The source for the .dll is available at the SeaLevel System's website.  The card it is interfacing with is a Route56 PCI CCA P/N 5101.
Thank you.
(3,825 Views)
I have had this issue ocurr before when I did not pass the correct parameters to the Call Library Function, or I did not specify the correct calling convention.
What does the prototype for the function look like?
(3,809 Views)
unsigned long SEAMAC_PortOpen(unsigned short int DriverType, unsigned short int PortNumber, unsigned long *hDevice);
(3,807 Views)
Try it with the calling convention set to stdcall. That convention is normally used on windows.
Wiebe.
(3,795 Views)
Thank you for the suggestion.  The VI runs without crashing now.  Can anyone expain why?
(3,792 Views)
You must use the correct calling convention to prevent stack violation.
Details can be taken e.g. from here.
Regards, Guenter
(3,786 Views)
To apply this (haven't actually read the link) to your application:
The main difference is that order the inputs are passed is reversed. So in your, the first parameter (a enumerated value) will be used as a pointer (the last input). When the dll code will try to write it's data to this pointer, it will crash.
Wiebe.
(3,777 Views)
