Using labview
Hello boss,
is there any one who can help me? I always record data (temperatures) every millisecond or second, but now I need to record data every 10 minutes, which part must i change so that my labview can record temperature every 10 minutes? could you send me an example program please?
thanks
regards,
(3,585 Views)
Hi okmanto,
Set the sample rate to 1Hz as you do right now. Then save every 600th sample...
Btw. when you want to change your "LabVIEW" you should attach your current VI!
(3,513 Views)
@okmanto wrote:
Hello boss,
thanks
regards,
I think it's pretty obvious that you have to change the part where you record temperature every millisecond or second.
Bill
CLD
(Mid-Level minion.)
(3,484 Views)
Hello, OKManto.  My Matlab routine normally analyzes waves from a seismograph (think "earthquakes"), but now I have to analyze recordings from a Rock Concert.  What part must I change so my Matlab code can analyze waves from the Rock recordings?
Now, isn't that a silly question?  Did I show you the code?  No.  Do you have any idea what I'm doing in the first case with my code?  No.  Can you say anything helpful to answer my question?  No.
So what would you say I should do so you can help me?  Attach your code and I'll take a look.
(3,466 Views)
