Using labview code of a USB-6003 on a USB-6001
I have recently came across a simple voltage measurement of a generator output.
The voltage across the positive and negative wires is measured by a USB-6003. I cant use the 6003 for personal use but I can use the code. I want to run the exact same experiment of voltage measurements but dont want to spend an extra 800 dollars on a USB 6003, I would rather spend 400 dollars on a USB-6001. But would the code that was designed for the 6003 run on the 6001 the same?
It is a simple two wired experiment of voltage graphing.
(422 Views)
If nothing much has changed, the same code probably should work if it is not too complex.
Just bear in mind that there is a difference in the sample rate and the bit resolution between the two USBs. So, you might need to modify the sample rate when using USB-6001.
https://www.ni.com/en/shop/data-acquisition/entry-level-usb-daq.html?srsltid=AfmBOoqzOR924_dbQ9HKIfo...
(402 Views)
