Using files from Robolab pilot as seed files for inventor level or lab view
I understand that the Lego RCX can be programmed by either
software(Robolab or Labview), but I find no "import" to transfer
programming steps from either the Robolab "pilot" programing level to
the "inventor" level or an export function for exporting into lab
view. Do such methods exist?
(3,156 Views)
There is no method that I know of to transfer a program from Pilot level to Inventor level. Now, you can transfer VIs you create in Inventor into LabVIEW after you have installed RoboLab for LabVIEW here.
(3,156 Views)
Also, there is some new beta software the will query your RCX for the code on it and write the Inentor code for you. This might be a good workaround for Pilot to Inventor. Look for it here.
(3,156 Views)
