Using file as input
I have a program with several  inputs from a DAQ card. Instead off  using the inpus I want to  use some data files as input. Anyone know how I can  do  that?
(2,667 Views)
If i understood your query correctly,
You want to read data from a file and use the values stored in it, instead of acquiring a signal through a daq card's AI channel.
correct??
To do this , just replace the data acqusition VI's of your program with file read VI's
You can use file I/O vi's on your functions palette.
Also browze examples shipped with labview, find Examples>> Fundamentals>>File Input and Output folder has a number of file reading/writing examples for you to get started
Any doubts, do ask
Regards
Dev
(2,651 Views)
