Using existing c code for usb-hid communication in labview
I want to write a simple temperatrue logger using labview and a external hardware which communicates over usb-hid. The external hardware uses an ATMEL 90USB162 µC and DS18B20 sensors.
Link to the hardware:
http://www.diamex.de/dxshop/USB-Temperatur-Sensor-Tester-fuer-DS18B20
The source of a a simple command line tool is available (see attachement), which reads out the temperature value of the connected sensors.
Is it possible to include this c-code in the labview application to simplify the communication?
Thanks a lot and best regards,
Michael
(3,431 Views)
I'm not that experienced at this personally (in terms of compiling C code into DLLs), but I believe the process you need to go down to call your C code in LabVIEW is to compile the C code into a DLL which you can then call from LabVIEW using a Call Library Function node (or you can try to use the "Import Shared Library" wizard to automatically generate SubVIs).
There's more information here:
http://digital.ni.com/public.nsf/allkb/DCB90714981A1F148625731E00797C33
(blog)
(3,407 Views)
Accepted by topic author MichaGue_01
I stopped using the exisitng code and change to http://ahidlib.com/index.php/ahid-dll-and-labview. This works fine for me.
Michael
(3,263 Views)
