Using button to control subVI.
Can i use a button in my main front panel to break out of a while loop in the subVI during execution?
(3,779 Views)
The attatched VI solves your probelm
(3,779 Views)
Thank you very much, Chris.
May i ask u if there is anyway to disable the button first until certain execution is executed, before releasing it to the user?
Im actually working on a project that manipulate data across gpib. If the user press the button to early, certain data will not be received.
(3,779 Views)
You can disable or hide the button using a Property node, and than activate or show after a certain execution.
(3,779 Views)
How is it done? Sorry to trouble you.Im pretty new in this.
Can you show me a sample prog?
thanks again.
(3,779 Views)
Hi lihui,
to make a property node you have to right click on the control in the
diagramm an then go Create --> property Node. To select a property you
have to right click on the newly created property and select property
--> visible, since visible is the desired property of the control you
want.
The attatched VI should help you to understand the functionality.
Greets Chris
(3,779 Views)
