Using a pulse generator for a sample clock on the same DAQ
Currently trying to figure out how to write a VI where I can use a pulse generator on one of the PF pins on my USB 6210 and utilize it as an external sample clock for edge counting. Trying to build a homemade tachometer and need to get continuous edge count readings off a hall effect sensor. Have tried using two separate DAQ assistants at the same time, one for the pulse generator and one for the edge counter and I keep getting errors pertaining to labview not recognizing the pulse generator as the clock. Any help would be greatly appreciated. Thanks in advanced.
(2,230 Views)
Do not use the Dreaded DAQ Assistant, and especially avoid its Evil Twin, the Dynamic Data Wire.  Learn DAQmx (it is much more straight-forward, transparent, and "safer" than the DDA).  There are DAQmx Tutorials, including one of my favorites -- search for "Learn 10 Functions in NI-DAQmx and Handle 80 Percent of your Data Acquisition Applications".
Here's another hint -- learn to use MAX to "demo" and configure your DAQmx Task.  You can even save the Task using MAX, reducing the Acquisition to 4 DAQmx functions and one While Loop (the functions being Start Task, Read (or Write), Stop Task, Clear Task, with a Constant wired to the Task/Channel input of the Start Task, and clicking the little "selector triangle" in the otherwise-blank Constant to choose the just-saved Task created by MAX, containing all of the Channels, the Device, the input ranges, the sampling rate, the sample number, etc.
(2,175 Views)
