Using a cygwin DLL in LabVIEW 7.0
Hallöchen!
I try to use a function from a cygwin DLL in a LabVIEW 7.0 VI. So
I wrote
void funcName(double values[], long number_values)
for (int i=0; i < number_values; i++) values[i] /= 2.0;
to the file test.cc and said (cygwin gcc 3.3.1)
gcc -c test.cc
gcc -shared -o hall.dll test.o
Then I included it as a shared DLL in LabVIEW, added the correct
parameter sequence and return value. The name of the function was
a little bit different (Z8funcNamePdl).
But: LabVIEW crashes every single time. Not matter what I say about
calling convention or reentrance. As soon as the "configure" window
is closed, *all* LabVIEW windows are closed.
What am I doing wrong?
Thank you!
Tschö,
Torsten.
Torsten Bronger, aquisgrana, europa
vetus
Message 1 of 8
(3,958 Views)
How are you passing the array in? LabVIEW arrays have a different structure than the traditional C arrays. As a quick test, try passing in a single DBL value by pointer for the first argument, and 1 for the second argument. This will hack LabVIEW into passing the right type into your C function, but it only works for one value.
The prototype in your C function needs to match the prototype you get from the "Create C File..." Dialog. There's a PDF document included in LabVIEW that goes into detail about LabVIEW arrays with external code.
Message 2 of 8
(3,958 Views)
Hallöchen!
LarsRoe writes:
> [...] LabVIEW arrays have a different structure than the
> argument.
Even a "void Test()" lets LabVIEW crash. I now say
extern "C" {
void Test();
void Test() {
return;
Granted, but quoting the gcc manual: "Good compilers never crash."
I didn't *start* the VI after all.
Tschö,
Torsten.
Torsten Bronger, aquisgrana, europa vetus
Message 3 of 8
(3,958 Views)
LabVIEW shouldn't crash just loading the DLL (not running it).
Can you call the DLL from other applications (e.g. a simple C program)? Can you attach the DLL? Thanks,
Lars
Message 4 of 8
(3,958 Views)
Hallöchen!
LarsRoe writes:
> program)?
Yes, I created the DLL (and the test program) according to
<>. The dll is linked
to the test program dynamically, so deleting the dll prevents the
program from working.
Sure, you find it here:
http://www-users.rwth-aachen.de/torsten.bronger/mydll.dll
Tschö,
Torsten.
Message 5 of 8
(3,958 Views)
Hallöchen!
LarsRoe writes:
So is the whole thing a candidate for a bug report?
Tschö,
Torsten.
Message 6 of 8
(3,958 Views)
I just downloaded the cygwin1.dll, and I'm getting the same issue.
It's hard to know what's to blame (LabVIEW, your DLL, Cygwin DLL, or some incompatibility) since it's all part of the same application, but it looked like it was the thread into the Cygwin dll that was crashing.
One thing to try is to call the DLL from a different application besides LabVIEW. Have you tried that?
-Lars
Message 7 of 8
(3,958 Views)
Hallöchen!
LarsRoe writes:
Which application could that be?
Well, a trivial EXE file generated with Cygwin can use it. As far
as I can tell, Cygwin has no own DLL file format.
However, I have no other development tool for creating a program.
Tschö,
Torsten.
Message 8 of 8
(3,958 Views)
