Using a closed circle indicator on pocket PC
(2,887 Views)
Hello, i've a little problem, i need to use a circular indicator (like a compass) on my pocket pc.
The problem is that the "gauge" indicator isn't supported for pocket_PC.
So, i've tried to make the "dial" indicator like a closed circle, on my PC it works ok, while on my pocket the aspect is automatically riconverted to a "dial" (with the blank space on bottom side), and also all the graphic settings are cancelled.
I need a closed circle because i must to indicate the winds.
Have you some idea? Someone can help me?
(2,883 Views)
Mohak,
unfortunately customized controls are not supported on LabVIEW PDA. This is why you are getting a different behaviour when running your VI on your Windows machine compared to your PDA Device. This means that they may work but it depends basically on what customizations have been made on the control.
We have filed a Product Suggestion in order to evaluate the possibility of making customized controls supported in a future release of LV PDA.
AlessioD
(2,863 Views)
