Using a DAQ trigger to activate TDMS
I wish to activate TDMS once a certain condition is met. Rather than using a boolean operation, however, I would like to use a digital trigger so I can gather some pre-trigger samples in my data. Is this possible? Thanks,
ntsirak1
(2,881 Views)
So you want to start logging to a TDMS file when a digital input bit on a DIO board goes active? It is possible to create an event that will trigger in that situation. Although I have never done it, I think you can trigger the event on an analog level as well.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,871 Views)
Yes, but I want the TDMS data to contain the pre-trigger samples as well. The data is also being continuously acquired in the background; I only want it to capture to TDMS at a certain point. Sadly, I think I'm going to need two DAQs. One to continuously capture, the other to trigger the TDMS.
(2,863 Views)
Not necessarily, as you acquire data buffer the current data as well as the previous N samples, Then when the tdms trigger occurs, dump the entire contents of the buffer into the file and start adding new data as it comes in.
Mike...
LabVIEW Champion
(2,855 Views)
