Using a C DLL with complex numbers from Labview
   So I'd like to try to use some existing C99 code to do calculations, and for the functions, the code accepts and returns numbers of the "double complex" type.   I've already spent half the day finding out the hard way that Visual Studio doesn't include the complex.h header, so before spending any more time trying to compile a DLL, does Labview actually even allow you to send and recieve complex numbers from a DLL call?
   When I open the Call Library Function node and go to Parameters, the closest return type I see is 8-byte double, but nothing about complex...  so..   I'm not even convinced that this will work..  has anyone done this before?
NI Hardware: PXI-7853R, PCI-5122, PCI-6733, PXI-1036, PCI-MIO-16E-4, PCI-6110
Computer Hardware: Xeon Quad Core - 2.33 Ghz, 8 GB RAM
Software: Labview 2009, Labview FPGA 2009, Vista 64-bit, MAX 4.6, DAQmx 9.0, NI-SCOPE 3.5
(3,033 Views)
Accepted by topic author noli
Yes, you can use complex numbers. See the example that ships with LabVIEW called appropriately "Call DLL". There's an example in there that deals with complex numbers. You may need to write a wrapper DLL, though.
(3,019 Views)
