Using XNET with sbrio-9627
Hello, I am currently trying to send binary files from an sbrio-9627 to my computer using an ethernet cable and the xnet library UDP write binary vi. Until now, I have tried to take the example Simple UDP sender given by the XNET library and run it on the sbrio, however it did not work as it gave an unusual error saying that the UDP Socket Write VI cannot be deployed. Therefore, I have tried a simpler example , just to open an IP Stack on the Sbrio but I am facing the following error.
Would you know a way to fix it? If there is more information needed from my part I am more than happy to share it as soon as possible.
(785 Views)
NI-XNET Ethernet API only works for PXIe-852x.
You can only use LabVIEW socket API in sbRIO.
https://tmesystems.net/
(747 Views)
