Using XNET in an installer
Hi all,
I having an issue creating an installer with XNET included. My program runs fine in development mode. No issues at all.....
When I create an installer, I found that my CAN device just didn't work. It seemed I needed to point the VI to my alias using XNET Database Add Alias (reading other posts). I did that, but still getting an error 1074384340. I am using the same alias in development mode and not sure why I am getting this error. It seems this error is caused by an invalid character in the database name?
This is the first time I have tried to build an installer with XNET. When dealing with DAQ's, you simply import your task list....that is what I am used to but I believe it is different with XNET. Do I need to install the XNET database editor on the target machine? This machine does not have Labview installed and is a clean test machine.
(2,722 Views)
Of course, after I post...I figure it out. It was all about file structure. The filepath wanted the .dbc in the path and the alias was the .dbc file without the .dbc
Example:
Filepath:        c:\test\cantest.dbc
Alias: cantest
(2,716 Views)
