Using XML-Files on RT-Tragets
Hi
i have an application which stores it's configuration in a XML-File. The Vi runs perfect on Windows as execution target.
But running the Vi on the RT-engine fails with error 1108 while loading the XML-formated config file.
error 1108
Possible reasons:
LabVIEW: XML value text is illegal or out of range for type and/or format.
The XML-file can't be illegal, because the same Vi works on an other excecution target.
Any ideas what's wrong?
Is the RT-engine unable to handle XML-files?
Regards Till
(4,439 Views)
Till,
that's true. Not all VIs are supported in LV RT as it states in the LV RT User Manual (7.0, page 1-7, 1-8). In your case the XML VIs require the MS XML DOM parser that is getting installed with LabVIEW on Windows and is unfortunatelly not available on the RT platform (Pharlap).
I don't know if there is a XML workaround or if NI will integrate other OS independent XML parsers which would run on RT.
You might consider to use the .ini file approach for the RT platform - I assume this should work.
Roland
(4,439 Views)
