Using WebDAV to transfer file to RT Error
Hi all,
I have difficulty to transfer image file to real time target (myRIO) using WebDAV. I have follow this https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019PlESAU&l=en-MY steps to configure the setting. I have locate the "Abdo.JPG" file in the target (home/lvuser/natinst/bin/Abdo.JPG). Below is my VI and the error shown.
Error1.pngThe possible reasons states LabVIEW: (Hex 0xFFFE1B3C) The requested resource was not found. What I missing? Someone please help me Smiley Sad
Thank you
Message 1 of 11
(4,823 Views)
I struggled with the WebDAV GetFile VI myself recently.
In the end I created an absolute path for the input "relative uri" in the format:
http://IP-address:80/"uri-output from directory listing"
Here's a screenshot:
Regards, Jens
Kudos are welcome...
Message 2 of 11
(4,793 Views)
Hi Jens,
Thank you for your concern. I modify my code as shown below:
Error2.pngHowever, I get another error Smiley Indifferent. Can you show me what my mistake? Thank you
Message 3 of 11
(4,776 Views)
I just realized now, that in your first post you already get an error after "Directory Listing".
According to the help for this VI, the input "relative uri" should be a directory and not the filename itself, i.e. just
/home/lvuser/natinst/bin
without your jpg-filename.
Regards, Jens
Message 4 of 11
(4,765 Views)
Regards, Jens
Hi Jens,
When I change the "relative uri" as /home/lvuser/natinst/bin, I get error at the same place (after "Directory Listing"). The error states :
Possible reason(s):
LabVIEW: (Hex 0x58BEC) Failed to connect to the specified hostname. Be sure the specified hostname is correct, the server is running and configured to accept remote requests.
Message 5 of 11
(4,763 Views)
Update: I change the target address. Now, the error after the "Directory Listing" is solve. But, the same error (LabVIEW: (Hex 0xFFFE1B3C) The requested resource was not found.) occurs after the "Get File" vi.
Message 6 of 11
(4,758 Views)
Not sure what's the problem now.
What is the value of the output "file list" of "Directory Listing"?
Regards
Message 7 of 11
(4,742 Views)
Regards
Hi Jens,
The output under "file list" of "Directory Listing" is it shows all the files in the target (/home/lvuser/natinst/bin). The error comes after "Get File" vi. Is it my "windows directory" is correct? Thank you
Message 8 of 11
(4,736 Views)
As already stated, but you probably overread that:
For the node of "Format into string", make sure that the first string is just the IP-address of your target.
The output should be something like this:
http://172.22.11.2:80/files/home/lvuser/natinst/bin/XYZ.jpg
Jens
Message 9 of 11
(4,724 Views)
Hi Jens,
The output for the resulting string now show:
http://172.22.11.2:80/files/home/lvuser/natinst/bin/README_File_Paths.txt
instead of:
http://172.22.11.2:80/files/home/lvuser/natinst/bin/Abdo.jpg.
I have point the "Abdo.jpg" in the "window directory" and the "Abdo.jpg" also have been located in the target (home/luvuser/...). Why the string cannot read my image files? Thank you
Message 10 of 11
(4,720 Views)
