Using Web Server in Labview 8.6
Suppose I have Single VI open on Server sytem & there are 4 clients.
Is it possible that all 4 clients can access or gain the control of VI running on the server.But the clients should not interfere with each other. This will help me to just keep on updating VI on server & the clients will just load that VI in to their system & run their task.
Also is it compulsory to Run Labview & open VI on server machine for Web Browser to work?Because I am using dynamic caling for all sub-VIs on server.
Can you please provide steps for Labview8.6 as well. Because one of the tutorial says that we have to build & deploy the VI from a project for Web Access/Server to work.
(2,551 Views)
(2,541 Views)
