Using USB-8451 for accessing SMB Slave
Can i use the following example to read a SMB(System Management Bus) slave device using USB-8451 (since SMB is derived from I2C) .
Hardware Input and Output > I2C and SPI > I2C Basic > Generate I2C Read.vi
Baburaj
SMSC
INDIA
(2,503 Views)
The following is the read and write sequence examples , I want to confirm that this sequence is done by General I2C Read.vi .
Example Write sequence:
1)      Slave Address 0x58
2)      Register Address 0x00
3)      Byte count 0x03 (to write 3 bytes)
4)      Data Byte 1
5)      Data Byte 2
6)      Data Byte 3
Example Read Sequence:
3)      Repeat start Slave address (will be 0x59)
4)      Byte Count 0x03 ( to read 3 bytes)
5)      Data Byte 1
6)      Data Byte 2
7)      Data Byte 3
Baburaj
(2,492 Views)
