Using USB-6008 to light up LED array(hardware)
I've created the coding to light up an array of LEDs at random, can someone teach me how to light up my hardware using the NI-USB6008 exactly as it lights up in the VI? thanks.
p.s: I've attached my VI and LED array schematic
(4,402 Views)
Have you taken a look at the documentation? Page 21, to be specific. The USB-6008 digital lines are open-collector. This means you have to wire them up to sink current, meaning you will need an external power supply.
(4,398 Views)
may I know how to do that? I'm fairly new to electronics and LABView.. thanks.
(4,389 Views)
Maybe it's wise to protect your outputs with some drivers :some I found , but they might not be the best suited... (they should be cheap (<.5$) and on Stock >1k at digikey just to give you an idea...
74as1034
74 11240
But since you want to start with electronics
read Horowitz/Hill: The art of electronics (library?)
Now build your custom discrete transistor drivers...
Greetings from Germany
Henrik
LV since v3.1
(4,379 Views)
You can also get LEDs that only draw 2mA. They are not so bright, but then you do not have to use a driver only a resistor
Which country do live in. I you live in Europe I might give you a vendor
I know Agilent has such a series of LED
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(4,368 Views)
