Using Trigger n Gate as Boolean or similar function to control other data
I have two devices connected to LabVIEW and I'm using Trigger and Gate to extract a segment of a waveform signal from one device. One device measures the waveform with varying amplitudes. Another device measures the number of particles detected. I was able to successfully extract a segment of the waveform triggered by high amplitudes with Trigger and Gate function. I used a boolean LED button to start the triggering, but end the triggering with the threshold specified in Trigger and Gate properties. However, I could not figure out how to extract data from the other device within the same timeframe as the triggered waveform. How do I create a Boolean function or a similar function to end the collection of data from another device (counter of particles) at the same time as the “stop trigger” specified in Trigger and Gate for the waveform?
(2,729 Views)
I am not sure what devices you are using, but would it be possible to send a trigger signal to your external device and use that trigger signal as a reference trigger??...but again I am not sure what kind of device you are talking about...could you give a little more information about what hardware you are using and what you application is trying to accomplish?
-Brett
(2,694 Views)
