Using Thresholds With Vision
Hello Community,
I'm using Labview Vision to analyze data collected from my microscope based instrument. The image I'm trying to analyse
is as below. I would like to average all of the red areas, representing a different morphology in my thin films. The image is floating
so I was hoping to simply use thresholding to select the red regions and then use that image to extract only values from red regions in the float image. However, when i plug this image into the Image threshold and output it to a binary (I16) I an error due to the image type even though threshold is meant to work with float images. The output image is defined as I16.
So i cast the float image into I16 and now i simply get a get a blue image with only 1 value.
The LV code is very simple. Really just a test. I attach a snippet here as well.
Any ideas on why this isnt working. I guess my casting isn't working.
Cheers
Jamie
(2,242 Views)
Hi LabLoko,
In the help of "IMAQ AutoBThreshold 2.vi", it says: "supported types: U8, U16 and I16".
So you need to convert your float image into an integer image (like I16).
To do that, a simple cast is not sufficient because your float values are surely in the range [0; 1], so they are all rounded to the same integer value.
What I would do :
 - Extract the float values as a 2D array with "IMAQ ImageToArray.vi";
 - Apply an ax+b so that the values are rescaled from range [0; 1] to the range of the integer type (like [-2^15; 2^15-1] for I16);
 - Cast the 2D array to the integer type;
 - Write the 2D array back to an integer image with "IMAQ ArrayToImage.vi";
 - Then you can apply your threshold function.
Find attached a conversion VI for that purpose.
(2,198 Views)
I think so, too. Maybe you need another  IMAQ Autthresholding function
is the value range of the float mage in [0;1]?
If yes, I'd guess you need to transform the float image to Color image in the value range [000000;FFFFFF] and then do global color thresholding
I can't test this with a vision licence right now, but here is my non-imaq draft:
1# make a screenshoot, crop and save as 24 bit png (you will probably work directly one the float 2d array..)
2# then extract only those pixels with R bigger than G and B
Spoiler
(2,192 Views)
On the front panel, right click the Image indicator, on the popup menu, select a color palette matches 16 bit image.
George Zou
(2,178 Views)
