Using SignalExpress with LabVIEW VIs
Hi everyone,
a short question about interaction of SignalExpress and LabVIEW: does the integration of LabVIEW Code work although LabVIEW is not installed? I may have an application where users need to use some VIs in SignalExpress but they don't need to edit them. So it would be nice not to have too spend the money on antoher LabVIEW license.
Cheers
Oli
(2,660 Views)
Hi Oli,
take a look into Knowledge Base Entry 3LAGNBL2: http://digital.ni.com/public.nsf/websearch/F6D5EF4620EE12EB86256FFE007D2086?OpenDocument, it tells you the requirements for doing that.
Furthermore you will find useful information about creating these steps in the following docs:
http://zone.ni.com/devzone%5Cconceptd.nsf/webmain/5A807DFBE89D7EAD86256ED30008D88A/$File/WP2466.pdf
http://zone.ni.com/devzone/conceptd.nsf/webmain/B19A4046EADBFA6C86256EE90078C35E
Hope it helps!
Good luck programming your plug- ins and kind regards
Stefan Smiley Happy
Impossible is nothing - nothing is impossible
(2,649 Views)
