Using Set Cursor.vi in an executable
I've attached an extremely stripped down version of code here:
When you run Untitled 2.vi, you can select any of the cursors in the enum and you will see it being set.
However, in the application.exe, only some of the cursors can be set.  For example, you cannot set the cursor to paintbrush in the exe but you can in the vi.
S G
Certified LabVIEW Architect, Certified TestStand Architect, Certified Professional Instructor
(2,544 Views)
Duplicate post.
Please keep the discussion in the original thread so that others can see the history.
(2,536 Views)
