01-08-2013 02:20 PM
01-08-2013 03:31 PM
Hi Houssam,
It's been a while since I last used the Sentinel dongles for a project. Having said that, here goes:
1) Trust me... you'll want to use the Sentinel software to program your dongles. I remember it was a pain in the butt to use the ActiveX COM object to communicate with the dongle via LabVIEW. I can only imagine the higher level of magnitude in complexity it would be to program your dongles using only LabVIEW.
2) Your ideas for using the Master, Developer, and User dongles is pretty much correct.
3) You'll want to program your LabVIEW application, in simplest form, to periodically query for the dongle identification information so as to perform a comparison check. If you choose to go the more complex and secure route, you'll want to program the dongles with various information using the Sentinel software so you can then use LabVIEW to query the particular information you're looking for.
Again, it's been a long time since I've used the Sentinel software, so I am a bit rusty. It's also quite possible that the Sentinel software has changed enough between then and now.
Good luck!
-J.C..
01-09-2013 07:45 AM
