Using Runge Kutta
My first attempt to use Runge Kutta failed miserably, and I don't know why. Here are front panel and block diagram:
I do not get any output. When I put a break point on the Times wire, it says Not Executed, and does not draw any graph.
What mistake am I making.
Girish
(2,487 Views)
Hi girish,
You only attach images of code. We cannot debug/edit/run images in LabVIEW!
Mind to attach your VI with all used data set as default in those controls?
Did you check the error output of the ODE function?
(2,481 Views)
Here is the VI.
(2,471 Views)
Accepted by crossrulz
Hi girish,
do you spot the difference?
(2,453 Views)
Deep.
Thank you.
Girish
(2,445 Views)
