Using Pocket Excel with LabVIEW PDA Module
Greetings,
I am very new to LabVIEW and I was wondering if it was possible to
retrieve information from a Pocket Excel file using LabVIEW PDA
module.  I couldn't find any "Read from Excel" VI on LabVIEW PDA
Module so this is the nature of my question.
I have a 1xn array of RFID tag IDs (scanned from RFID reader).  I also
have a database (in Pocket Excel, see attached) that contains the information of the
RFID tag IDs within the 1xn array.  I am attaching an Excel file that
illustrates our database.
For example, if I have an array of: [1234, 1256, 1265], I would like
LabVIEW to look at the first element, 1234, search for it in Excel,
retrieve the information, "Jerry," "A-," and "Lab," then display  it.
I would like to also add a time stamp when this retrieval is done.
Next, I will want LabVIEW to look at the number 1256, search the Excel file and find
"Joe," "AB," and "Patient's Room."  I would like this information to
be placed in a table in LabVIEW's Front Panel.
I know I should use a while loop using Auto-Indexing, but have no clue
as to how I could do this
I will appreciate ANY HELP!  🙂
Thank you!
-Amal
Amal Patel
Message 1 of 11
(13,764 Views)
A simple search for "excel" and "PDA" would have brought you to this recent thread. That should probably be enough to help you.
___________________
Try to take over the world!
Message 2 of 11
(13,751 Views)
When I ran the Search 2D Array.vi you created in the thread you linked me to above, on my PocketPC, it gave me errors.  I think it gave me errors because Excel is NOT available on the PocketPC.  The only spreadsheet program available on the Pocket PC is Pocket Excel.  Is there a workaround this?
Amal Patel
Message 3 of 11
(13,716 Views)
Did you read the entire thread?
LV does not support ActiveX on the PDA, so you need to save the file as a CSV file. Read the entire thread.
___________________
Message 4 of 11
(13,691 Views)
Greetings 🙂
Yes, I did read the entire thread.  The problem is I am not being prompted on the PDA to open a file.  I know I'm supposed to have a *.csv on the file.  I modified your code from Search 2D Array.vi, and I got errors when I ran it on the PDA.  It says, "App failed.  Error code 160981006.  Bad input argument to function."   I attaching your modified VI.
Thanks 🙂
Amal Patel
Message 5 of 11
(13,647 Views)
"Bad input argument to function" - My guess is that the PDA module simply has a different behaviour on this than the PC - when using the read function without a path input, it takes an invalid path instead of showing a dialog asking you to find the file. The solution is to wire the path to the file into the function (either by showing a dialog, if possible, or by obtaining the path through other means).
In any case, you should be aware that this was only a very quick example meant to show the searching code. It was not meant to be taken as is and used in real code.
___________________
Message 6 of 11
(13,633 Views)
That's too bad!  I am very new to LabVIEW, and do not know how to prompt the user to enter a file path.  Is there a VI that can do this for me?  I am sooo desperate.
Thank you Smiley Very Happy
Amal Patel
Message 7 of 11
(13,630 Views)
To know if there is a VI that does this, the easiest thing is to look at all the VIs in the file palette.
You should find it under the surprising name "File Dialog", but I don't know if it's supported in the PDA module.
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here, here, here, here and here are a few you can start with and here are some tutorial videos. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
___________________
Message 8 of 11
(13,622 Views)
Well I fixed it.  Thank you for your help.  I only had to put a while-loop around your code and use a Read from Text VI, instead of Read from Spreadsheet VI.
I'm attaching my modified code below, if anyone else needs it in the future.
Amal Patel
Message 9 of 11
(13,543 Views)
Muchas gracias por el Ejemplo... me sirvió bastante.
Aquí les adjunto un complemento que desarrolle, para insertar o cambiar un registro del arreglo y volverlo escribir en el archivo plano sin añadir un nuevo registro.
Ojalá sea de utilidad para alguien.
Saludos.
Nito
Message 10 of 11
(5,406 Views)
