Using Peak Detection software and adding the entire maximum amplitudes that it finds from my graph
I'm trying to take my maximum amplitudes and multiply them by some constant that i determine and then have each amplitude added together into a 32-bit integer. An example of use is sensing the accleration of 5 punches multiplying the max amplitudes by a constant, add them all together, and output a "score" for that persons punches.
Attached is a simple version of my code. The amplitdue output from the Peak detection is where I'm having trouble because it is outputing an array and i want to add all the values together to a single 32-bit integer.
Thanks for the input, it is greatly appreciated!!!!!
Zack
(2,552 Views)
Accepted by topic author zaal3595
Zack,
Try using an Index Array followed by an Unbundle by Name to get a numeric output. Then you can use Add Array Elements to sum them.
Let me know if that is what you were looking for!
Katie
Katie Collette
(2,529 Views)
