Using PXI 6280 on PXI 1065express chassis
Hi all,
I have a PXI 6280 hybrid card and a PXI 1065express chassis. I would like to continously generate pulses from the counter 0 of the 6280 card as shown below.
In the figure shown i have used 80mHz timbase and i have generated the pulses. But the accuracy of 80mhz time base is only 50ppm. So i would like to use the PXIe 100MHZ backplane clock as timing sorce with 25ppm accuracy. My 6280 card is a pxi hybrid card, but i have inserted it in a normal PXI slot in the chassis and hence i dont see any option to select pxi 100mhz clock as time source. My question is whether i would be able to select 100mhz clock as time source if the card is inserted in one of the pxi express ready hybrid slots?
Regards
Deepu Jacob
Waiting For the inner calling 🙂
Message 1 of 1
(2,984 Views)
