Using PCL with LabView.
I am using Point Cloud Library(PCL)(Coded in C++ Visual Studio 2010) to get data from kinect and process it.Now,I am using Labview for the main program.So is there any way of using the PCL code in Labview.Will a DLL do it.
Harsha
(3,839 Views)
Hey Harsha,
If you have a DLL for your PCL code you can bring its funtions into LabVIEW using a Call Library Function Node.  Check out these directions for using the Call Library Function Node.
Tutorial: Configuring the Call Library Function Node to call a Simple DLL
Eric L.
Applications Engineering Specialist
(3,755 Views)
Hello, I have a project like yours and I'm having the same problem: use the PCL with LabVIEW. You could generate the dll? If yes, is it available to me?
Thank you!
(3,686 Views)
