Using Ocean Optics Maya with LabVIEW
Glad I could help... BTW - Kudos are the best way to say thanks! Smiley Happy
Message 11 of 14
(1,066 Views)
Do you know if the drivers operate correctly in windows 7?. I have installed the files but appears error in code 18 in the window of device manager
Anyone have a solution?
Message 12 of 14
(989 Views)
I could be wrong, but the NI drivers might be using the XP .INF files. If so, it's pretty easy to make your own win7 versions - and then you should be able to use the NI software. Take a look at this link - you only need to create the infs. http://www.ni.com/white-paper/4478/en
Message 13 of 14
(985 Views)
I believe if you look at the instructions that came with the NI drivers they describe both the OOI driver conflict and how to resolve as well as instructions on how to install the .INF for Vista/Win 7 and XP and below.  If you are having an issue not fixed by the directions can you please de3scribe exactly what it is.
Message 14 of 14
(980 Views)
