Using NI USRP driver
I'm using NI USRP 16 with Ettus USRP X310 and was wondering if there's a way to determine what FPGA version it uses? I think its UHD_release 3.9.7 but I'm not sure. I ask because I would like to upgrade to either NI USRP 17 or 18 and wanted to know what the release would be to use with GNURadio as well. Is there an NI USRP version that uses the UHD_release 3.11.0? Thanks.
(2,734 Views)
It looks like you are intending to use the device both with the NI-USRP driver as well as UHD. This is the process you will need to follow to make your device compatible when doing so: https://kb.ettus.com/Converting_an_X310_into_an_NI-USRP_Rio. Is there a particular reason you are trying to swap between the two platforms?
Sunayna R.
Applications Engineering
(2,662 Views)
