02-13-2012 01:29 PM
I am working on testing products that use the TI LI-ON "Gas Gauge" chipset. The chip talks smb bus and has a chip address of 0x17. In order to access some of the functionality you have to do a series of writes to register 0x77 with data 0x48 followed by a read of register 0x78.
I can talk to the device all day using the TI-2300 smb adapter but can't seem to figure out the sequence required to stipulate the chip address 0x17 and then the register address(s) 0x77 & 0x78.
So I guess the bottom line question is.....how do you handle chip addresses with the NI-8451?
Solved! Go to Solution.
02-16-2012 10:28 AM
Hi thouston,
Since SMB is derived from I2C, I would suggest taking a look at this document: Using I2C with LabVIEW and the USB-8451. It covers device addressing in both basic and advanced modes in addition to other useful information on using the 8451.
Tim W.
Applications Engineering
02-22-2012 01:19 PM
I got all the register reads and writes working, along with a block read, but can't seem to figure out the block write. I set everything up the same as a block read but substitute the write VI instead of the write/read VI. I get no errors, but no data is stored.
Both the read and write VI's are attached. The read works but the write does not.
02-23-2012 08:49 AM
Have you taken a look at the I2C/SPI examples that come with the 845x driver? They're in the NI Example Finder (in LabVIEW go to Help>>Find Examples). From there go to Hardware Input and Output>>I2C and SPI. I'd suggest trying either the General I2C Write (in the I2C Basic directory) or General I2C Write Script (in the I2C Advanced directory)
Tim W.
02-24-2012 01:55 PM
I figured out the answer. The chip required a PEC byte at the end. I had to calculate the CRC and add it to the transaction among other things.
02-25-2012 11:29 AM
I think i'm having the same problem trying to write to the bq20z95 chip. Could you post your solution code? That'd be a big help.
CC
