Using Matlab code in LabVIEW
I have never used LabVIEW and I am wondering if there is a way to run Matlab code in LabVIEW. If so, how would I do it and are there any special instructions or tips I should know about?
(3,310 Views)
What is your LabVIEW version?
Do you have matlab installed on your computer?
In older LabVIEW versions, you can only use the matlab script node, which requires that you have a copy of matlab installed.
In newer versions, you have two more alternatives that don't require the purchase of Matlab:
  1. Use a mathscript node.
  2. Use a scilab script node.
Information on mathscript: [broken link removed; mathscript is no longer supported]
There is even a mathscript forum here: [broken link removed]
(3,302 Views)
> &nbsp;
> &nbsp;
> - Use a mathscript node.
> - Use a scilab script node.
> Information on mathscript: <a href="http://zone.ni.com/devzone/cda/tut/p/id/3502" target="_blank">http://zone.ni.com/devzone/cda/tut/p/id/3502</a>
> Information on scilab: <a href="http://zone.ni.com/devzone/cda/epd/p/id/657" target="_blank">http://zone.ni.com/devzone/cda/epd/p/id/657</a>
> &nbsp;
> There is even a mathscript forum here: <a href="http://forums.ni.com/ni/board?board.id=MathScript" target="_blank">http://forums.ni.com/ni/board?board.id=MathScript</a>
Thank you, for providing information on the availability of the Scilab
Script Node for Labview.
Howard
(3,255 Views)
