Using MATLAB data in LabView
Hi, I have MATLAB data file, can I use it in LabView? or can I convert this data to a CSV file?
(2,422 Views)
Yes, you can work with MATLAB data files in LabVIEW.
Please refer to this article - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000001DmPyCAK&l=en-US
Santhosh
Soliton Technologies
(2,419 Views)
I didnt mean m file, I meant MATLAB data like the attahed.
(2,378 Views)
The article talks about the ".mat" file and not the ".m" file.
Due to the low resolution of the image, I couldn't figure out the actual file format you're intending to use.
Santhosh
(2,366 Views)
Sorry, I attached a better image.
(2,361 Views)
I don't see the extension, if the file extension is ".mat", then this article discusses how read/write/modify those MAT files in LabVIEW.
Santhosh
(2,349 Views)
