Using Latest SQLite Library by JDP Science - Toolkit in Labview 2012
Hi all,
I'm trying to create a database using the SQLite API for LabVIEW (specifically, version v1.16 from VIPM). The final deployment. is it compatible with LabVIEW 2012 (32-bit), since that is the version installed on the customer systems.
I would like to confirm a few things:
  1. Is SQLite API v1.16 officially compatible with LabVIEW 2012?
  2. If not, which is the latest version of the SQLite API that supports LabVIEW 2012?
  3. Can I develop in LabVIEW 2020 or more and save all SQLite VIs for previous version (2012) without any known issues?
(1,141 Views)
You can easily verify the according compatibility yourself in VIPM by looking at the supported information for the package.
The package you refer to has following supported versions:
1.9.3.81 until 1.16.0.115 supports LabVIEW 2013 and newer
The latest version that supported LabVIEW 2011 and newer is 1.7.3.65
Why JDP moved from 2011 to 2013 with version 1.9.3.81 is up for speculation. It could be because he did not like to work in such an ancient version as 2011 anymore or it could have been that he was using a feature that required 2013. It will be up to you to do the necessary research work to check that your application will still perfectly work when backsaved to 2012 and run there. Expecting others to do that work for you when you need to use such an old version is a bit lame.
Rolf Kalbermatter  My Blog
(1,115 Views)
Thank You for the response.
The issue is, my organization owns only LV 2020. But the customer requested for the compatibility of  LV 2012. It's ok, I will find some way to test the VI in LV 2012 and will update soon.
(1,062 Views)
