Using Labview with Java Applets
I want to use LabView instruments in my Java Applets. Is it possible to call virtual instruments from applets?
(3,851 Views)
Gaurav,
Yes, it is possible, but it might be easier if you use Remote Panel (LabVIEW 6.1) or an ActiveX component (Application Builder). To have Java and LabVIEW communicate with your applet, I can only suggest using the Application Builder to build your VIs into a DLL and then use the JNI to talk to this DLL. This may work fine outside of a browser, but I don't know if it will work inside a browser or not because each user will need the DLL. The best way to do it would be to have the Applet redirect the user to a Remote Panel web page where they can control the VI from there.
For more information on Java and NI Products, see the link.
Randy Hoskin
Applica
tions Engineer
http://www.ni.com/ask
(3,850 Views)
Thanx for your reply Randy,
Infact our requirement is to use Labview models in a non-browser Java application developed in Swings.
How can we display and manage a vi in a Swing Panel ? We will appreciate if you can send some sample code to call a vi from Java Swing Application?
Will the demo version of Labview support this feature?
(3,850 Views)
