Using Labjack U12 to control stepping motor with Labview
For a senior project I am trying to use Labview to control a stepping motor through a Labjack U12 Board. I need to know how to set up the Labjack in Labview for DAQ.
(4,343 Views)
the LabJack cannot be set-up for regular LabView DAQ.
But: There are vis in the LabJack distribution, located somewhere under C:\Programs\LabJack (look out for ljackuw.llb). There are also several examples. The vis simply mirror the corresponding c library functions, as they are described in the LabJack documentation, so that should be a good starting point.
Best regards
Matthias
(4,343 Views)
Just download the LabVIEW drivers from the labjack homepage. You only need
one VI...
Btw. are you sure the outputs can deliver enough current to drive a stepper
motor?
Wiebe.
"Uha" wrote in message
news:506500000008000000D6C20000-1077587809000@exchange.ni.com...
(4,343 Views)
Do I need to configure the Labjack with the Measurment and Automation Tool in order to use it and if I do, how would that be done?
(4,343 Views)
no, this is not possible as I explained before. Just use the vis delivered with the LabJack or downloaded from the website.
Regards
Matthias
(4,343 Views)
