Using LabView with SR-830 Lock-In amplifier
Greetings all,
I am a newbie to LabView and I am using it to work with the SR-830 lock in amplifier. I am using the SR-830 to measure light that has been captured by this light detector
The goal is to capture the signals from the detector (which would be a sine wave) and plot it on a chart (alongside the reference frequency). Hence, I can see the phase difference between the two waves.
I have been experimenting with the instrument driver on LabView and some example VIs. My two questions are:
 1) If I were to run the example VI (attached in this question), can I just plug in the light detector into Channel 1 and run the program? Since the reference voltage is already set.
2) If I want to output the wave from the detector on a chart, can I just route the output of the Fetch Buffer VI to a chart (as highlighted in the screenshot)? Since the output is an array.
I have read through loads of threads and have been unable to find a solution for my question. Any help will be appreciated. Thanks.
Message 1 of 1
(2,337 Views)
