Using LabView (Output to file function) to retrieve GPS RMC data
Hello Everyone,
I was wondering if anyone knows the process of getting the RMC data from a GPS unit into a labview file.
I already have it being processed by the program, and now I need to acquire the data and put it into a file where I can analyze it. The tricky part for me is getting it into a file (speed, directional properties, latitude and longitude) and organised so that I can shove it into excel and do my calculations there.
If anyone has any tips or answers, it would be greatly appreciated 🙂
- Luke
(3,376 Views)
If you can interface to the GPS unit, it should not be problem to write data to a ASCII file. Are you using a RS232 link then communication with your GPS?
Then the data is in the computer you have several options for parsing the string. A RMC data may lock something like this $GPRMC,123519,A,4807.038,N,01131.000,E,022.4,084.4,230394,003.1,W*6A The first thing to do is to create an array of strings using the
 "Spreadsheet String To Array Function" and "," as the delimiter
EDIT: Take a look here also http://www.gpsinformation.org/dale/nmea.htm#RMC
Message Edited by Coq rouge on 06-03-2009 06:05 PM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,366 Views)
