Using LabVIEW shared variables to communicate with an Allen Bradley SLC500 PLC
Hi all,
I need help to use LabVIEW 8.20 and shared variables to communicate with a software emulated Allen Bradley SLC500 PLC through RSLinx OPC Server.
I use RSLinx Gateway 2.42, RSLogix 500 7.1 and RSLogix Emulate 500 4.0 on a PC running Windows XP Pro SP2.
My application requires to write and read data from an AB's PLC using a LabVIEW VI as an HMI (Human Machine Interface) application.
Using the interactive procedure I successfully create the OPC client instance as well all the input and output shared variables; also I am able to bind them to the right PLC registers using the browsing capabilities of the LabVIEW shared variables engine.
However, the problem is that I am only able to write from LabVIEW to the the PLC's internal registers; when I attempt to configure and use a variable to read or to read/write from any PLC register the shared variable engine always returns an error -1950679030 (Unspecified error) from the function ni_tagger_lv_read.
Placing a shared variable indicator/control on the front panel the small connection marker becomes green only when the variable is configured as write only; if I configure the variable as read only or as read/write, the connection marker is always red.
It is also strange to observe that also the write operations return an error code -1950679030, but the operation completes successfully (the affected PLC registers are correctly modified!); to avoid that these errors cause the VI to show a blocking dialog box on the screen I am forced to attach an error indicator to the error out terminal of the variable.
Can anyone help me to solve this strange problem?
Please note that I am interested in using shared variables to solve my problem because I am interested to use also logging and alarming capabilities of the LabVIEW shared variables engine; I cannot consider the use of DataSocket functions because they don't grant those functionalities.
Thanks in advance for any suggestion.
Message Edited by frada on 10-26-2007 05:46 AM
(3,885 Views)
Hi Frada,
I found the following post that is related to your error code:
Maybe the error is related to the timing of the readings.
Are you sure that all your items can be read and written? Maybe some of them can only be read or written.
Hope this helps,
Marco L
(3,822 Views)
