Using LabVIEW code in c#
Hi could you please let me know how is the best way of using LabVIEW code in c#. I see there are 2 options , making a dll or ,NET interop. Could you please let me know which one is better
I also have another question. when I want to make a dll or .NET I need to add my source VIs. I haev used many SubVIs to my main vi. Do I need to add all the SubVIs to Exported VIs or I need add my SubVIs to Always Included?
(3,537 Views)
Unless you are calling a subVI dynamically, you don't have to do either.
(3,504 Views)
I can add the interop Assembly to the c# program and I can see the LabVIEWExport but I don't have access to the VIs I added to the LabVIEWExport . Could you please let me know how can I use a LabVIEW assembly in c#?
(3,467 Views)
I use teh following code in c# to call the exported VIs
using NationalInstruments.LabVIEW.Interop;
using InteropAssembly;
and then
 InteropAssembly.LabVIEWExports.
but there is no function to ahev access to the exported VIs. I followed all the steps and then built the .NET assembly in LabVIEW but I don't have access to any of the exported VIs
Could you please help me
(3,451 Views)
