Using LabJack VIs in LabVIEW
Hi, I'm using LabVIEW with a third party DAQ card, the LabJack U12. I know that its drivers are supported by LabVIEW, but I can't figure out how to add the LabJack VIs to the library. when I added the includes VIs into the user library, then ran LabVIEW, the user library was filled with blocks with question marks in them. Any suggestions on how to fix this?
(3,105 Views)
You may have to copy the LabJack library file (the folder where that is located) to the addons folder (directory) so the path in Windows Explorer would look like: vi.lib\addons\LabJack. With a new folder containing the LJ library files. I think this is something I had to do on atleast one of the computers I use.
Or you can ask the LJ support at: support@labjack.com. Or you can post in the LV section of their forum on their website, I'm sure they or someone would be able to help you there as well. It probably wouldn't be a bad idea to e-mail them anyway, they have great tech support.
Message Edited by MAH2681 on 03-31-2005 04:54 PM
Using Labview 7.0 and 2010 SP1 with Windows XP and 7.
(3,091 Views)
