Using LAbView 6.1 ActiveX with ASP
I have LV6.1 installed on Win2k with IIS 5. My app is built w/ App builder and the ActiveX server enabled. I wrote a simple asp script to access a vi's data and write it out in html. The problem is that the script only works when my app is not running. If my app is running I get a 'can not create object' error from IIS. I'm basically lost as to what the problem is and apreciate any help. My asp script is attached.
Thanks...
(2,974 Views)
The problem is that when the VI is running you can't open an object reference to it. Same is the case when you open Automation refnum in LabVIEW to another running VI.
I don't know how fast you want to update this page, but you can make VI write to file and then have ASP read that file and display the text!!!!may be??
Abdullah R
(2,974 Views)
