Using Keys of Shortcuts in a Subpanel
I HAVE An APPLICATION THAT INSERTS VI'S IN SUBPANEL. Does THOSE VI´S THAT you/they are INSERTED IN SUBPANEL POSSESS BUTTONS THAT NEED to HAVE KEYS OF SHORTCUTS, do they PUT WHEN THAT SAW it is OPENED IN SUBPANEL, don't THE KEYS OF SHORTCUT OF THESE BUTTONS WORK, WHAT should I MAKE?
(2,488 Views)
If I understand your question, the issue is whether key navigation works for VIs in subpanels, and the answer is no. You will need to trap them on the VI that contains the subpanel and pass them to the VI in the subpanel in some way (like firing an event).
Mike...
PS: You might also want to repost your question in your native language as there are a large number of international users on this forum.
Certified LabVIEW Architect
LabVIEW Champion
(2,479 Views)
