Using Intermec printers to print through LabVIEW
Hi Yuange
I have the same problem now I want to print barcode from my pocket pc to intermec printer via serial port
Can you tell me how you used the fingeprint to do so ,as I tried IPL and the printer doesn't respond
Thanks Very Much
Message 11 of 12
(1,296 Views)
Hi Saso,
   try to use the Advance Serial read write example program from Labview.But you need to refer to the manual for which command need to send.Please follow as what yuangi did.Hope is  work.I attached the VI for you.
S.Ahmad.
Message 12 of 12
(1,271 Views)
