Using HP89440A Vector Analyzer. Getting an -130 error query saying invalid seperator, instrument specific.
not sure how to fix invalid operators. getting data off the machine and onto labview, but error still shows up, also how do you wire it up to get the data to write to a file. i know the function, just not where to wire it to.
(2,920 Views)
We would need more specific information to determine
exactly what the error is. What command were you
sending? Most likely you are missing a space, comma,
colon, etc., or used the wrong one of these separators.
You may still be getting data, but a parameter may
not be set the way you want it to be. Your data
could be in error. Like the oil light on your car,
never ignore error messages.
As far as writing data to a file, turn on the context
sensitive help. It is generally pretty good at
explaining how to wire things.
Les.Hammer@CompleteTest.com
(2,920 Views)
