Using Data Socket Read with Application Install?
Trying to get a Datasocket Read to work with the application installer on 8.5.  I'm guessing somehow I need to bundle the internet toolkit with the application installer...but how?
See included vi example.
ShotSimon
(3,422 Views)
Hi, Shot this is Tyler. Can you try inserting the LabVIEW 8.5 CD into your drive when you build the application and then instruct LV to look in your CD drive when it prompts you to be pointed to the distribution. I believe that the CD might contain files that you did not install on your computer, and LV needs to have access to those files to build your particular application. Let me know if that works out for you or not.
(3,414 Views)
Following up, I downloaded this VI and added it into a new project and built an application from it successfully without encountering any problems. I'm using LabVIEW 8.5 Professional Development System and I believe when I installed this software I told the installer to install all components.
(3,406 Views)
Thankyou...that's all it was. ShotSimon
(3,397 Views)
