Using DLLs in LabView.
Hello! I need to use a function from DLL, but  arguments  of this function are C structures. How can i work with it in LabView? For example, my function returns a pointer to structure. How can i retrive it? Thank you in advance!
(3,072 Views)
There is a chapter about calling DLLs in the user manual (Help>>Search the LabVIEW Bookshelf). There is also a lot about it here [broken link removed].
Basically, you need to use Adapt to type as an input and wire a cluster into it.
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here and here are a couple you can start with and here are some tutorial videos. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
___________________
Try to take over the world!
(3,059 Views)
Thank you very much. I'm new here  and  so don't know many things.
(3,053 Views)
