Using Cursors - snap to point
Hello everyone,
I would like some explanation on cursor functionality. I have a cursor on an x-y graph and I would like to use the drag function or enter the co-ordinates and have the cursor snap to this point.
My x-scale is set in 0.1 increments. I would like to only enter the x co-ordinate and have the cursor snap to the appropriate x-y co-ordinate on the selected plot. If I set it programatically using the 'cursor.posx' property node, the cursor moves to an x co-ordinate 0.1 below the one I set.
any ideas would be appreciated.
thanks.
(4,036 Views)
Apparently, I don't have this kind of problem. Try to compare the attached vi with your own to find out the origin of the different behaviours.
CC
Chilly Charly    (aka CC)
(4,027 Views)
There is nothing that I can see in your example to my test vi, except for the data generated. If you have the time, can you please take a look at my vi, Im probably missing something very simple.
thanks
David
(4,015 Views)
David,
The difference is that your points are unevenly-spaced along the X axis, and charly's weren't. The easiest solution for you is to use the Cursor >> Cursor Index property instead of Cursor >> Cursor Position >> Cursor X. If you set this property to 0, the cursor will snap to the first point; 1 snaps it to the second point, 2 to the third, and so on.
You will have to change your UI a little bit if it's critical to display the actual X value, but since the X value is actually shown in the cursor palette, maybe you can just change your control to say "data index" or something and be satisfied.
--John
(4,006 Views)
HAAAAAAAAAAAAAAAAA !
That's a nice one !!!
Just modify the scale of your graph, to display only a limited range of points, for instance 0 to 5. Things work perfectly there... Or similarly, on my example, set the X axis to 0-10. Things are going nuts ! Stop the vi, and increase the size of the graph, keeping the scale to 0-10. Rerun it. Works fine again !!!!
The problem is apparently related to the distance in pixels between the X positions. Since local time is 2.5 am, I'll leave this challenging issue to somebody else !!!
Thanks for this enlighting question. I'll have nice dreams !!!
CC
(3,993 Views)
In this KB you can see that it is not recommended to use the Cursor>>X-Position property in this case. Attached to this post is a snapshot of one way you might use the Cursor.Index property to implement the behavior you are looking for.
Scott Y
NI
(3,971 Views)
